Double glazing guy was measuring our opening for a patio door system. He said one side was about 10mm to 13mm higher/lower than the other side which is 4.1m in width. There is a lot of dirt on there so not sure if it impact a straight measurement.
When you builders do your work, I guess its never going to be 100% perfect, so what tolerance level is acceptable over such a span?
Separately, to what extent do builders get involved in the electrics except the connections at the fuse board? Do you at least run the cables to the sockets and lights?
