We've often discussed this at length, and it's a case of swings and roundabouts. I could equally ask you whether you would want 'unnecessarily earthed' metal pipes/taps/baths/whatever around for you to touch at the same time as you were touching a damaged kettle (or whatever) flex.Not when you have metallic pipework extending throughout the house between different locations. Would you really want, say, a damaged kettle flex draped over a kitchen tap to leave all the pipework and taps in the bathroom live?Why do you feel that internal pipework needs bonding? Were it not for the almost inevitable 'incidental' connections from pipework to earth (CH components, immersions etc.) it would arguably be safer not to bond/earth internal pipework, when the incoming supply was in plastic, wouldn't it?
If it were achievable (which, in practice, it isn't), the ideal would be to have no exposed earthed metalwork in a house. It would then not matter if you touched something which was at 230V above earth potential.
