- Joined
- 11 Dec 2007
- Messages
- 413
- Reaction score
- 5
- Country
JB's? I'll assume that's something like the floorboards then in which case the floorboards are down, however because damp work was being done there is a hatch in the floor so there is access to the subfloor where all the cabling is.
I've just done the light test you mentioned but it didn't teach me anything. Turned every light on in the house & started turning fuses (MCBs?) off. I set it up in the way where that 2-switch operated upstairs landing AND the kitchen/diner (when it obviously shouldn't). This time when flicking it it also turned the living room light on when it hadn't previously done.
I turned other fuses off 1 by 1 & none of them interfered with the lights at all. Made no difference.
I know i'm to get in touch with the builder boss & i know i've to tell him the electrics are all a bit all over the place, but other than that i'm explaining something that i really don't understand so what should i be telling them so they know what the crack is?
I can't just say some bloke on the internet told me it's been done wrong & i should have a new wire to the fuse box & i should have something called an RCD because in my experience the person you're talking to about it says that everything is A-ok & stop worrying because you don't need these things.
I'm not saying anyone is right/wrong here, just that it can be quite iffy trying to explain something that you actually know nothing about (me+electrics).
