The garage will ultimately become another living room based on my current plan.
Are you sure you'll be able to hear eastenders over the noise of that new compressor?
Are you sure you'll be able to hear eastenders over the noise of that new compressor?![]()
The CU could do with upgrading, but it depends on what is happening down the line... if a rewire is planned then its a false eccomony to fit a new CU to the existing installation, fix problems to allow RCDs to hold in etc.
The point behind my comment in jest was aiming at, what is eventually going to happen to the compressor? My suggestion of a board in the garage was based on it being a small workshop, you could have this area sorted out and then not have it touched during the re-wire of the rest of the property, but if its to become a lounge then that changes things somewhat... you do not want a sub-board on the wall above your television!
Typo/autocorrect fail of the year so far goes to Eric!The inverter has the ability to change the frequency so it starts slow and builds up speed more genitally than other starting methods
Even without the new stuff, is that not a 60 amp maximum switchfus, for the whole house
So a new CU replacing this switch is best approach?
D
