The photos may be misleading, but 'business part' looks fine. If that is the case, then, if you could find one, you presumably could just replace the rusty front plate? (and then relocate it to wherever you wanted).View attachment 91176 It is the same switch. Here it is with the front taken off.
And for your edification and delight, an idea contrary to both that and the philosophy of "life's too short".you presumably could just replace the rusty front plate?
Indeed - but it was not me who asked the OP why he wanted to replace the switch (thereby implicitly suggesting that it might not need replacing), when he had only asked about how to do itAnd for your edification and delight, an idea contrary to both that and the philosophy of "life's too short". ... Wire wool + phosphoric acid + a degreaser + hammerite + a few hours work = front plate rejuvenated.you presumably could just replace the rusty front plate?
A common name for connector strip:What is choc block?
If you do what you propose it will no longer be earthed via the existing switch box, so it depends on whether there's an earth connection at the other end of the conduit.The existing earth wire can be seen secured under a screw in the back box. If I remove the old switch and replace it with a plastic junction box connected to new cable running further up the garage to a new plastic switch and plastic back box with an earth terminal in it, will the metal conduit that is connected to the old metal switch ( and that the old cable will still run along to the new junction box) still be earthed?
