I look after the lighting in a church, which is basically a set of around 20 500w halogen lamps in fairly old open reflectors.
The lamp life of these seems rather short, I'm changing them after what can't be more than a couple of hundred hours use.
Now I am 99% sure this is just luck, but I wondered whether there are any possible other explanations for the short life. I can't see how noisy mains could affect lamp life (unlike say computer equipment), but thought I would check with the experts.
These are true 500w lamps, not the economy ~400w variety, in an open reflector. Typically it seems to be the wire at the cap end (ie within the glass, not the lamp tungsten itself) which goes.
The other twist is that we had 3x LED floodlamps (50W) fitted a couple of years ago, which also failed. Again that could just be a bad batch, but it does seem slightly odd!
They are all run off a straight set of switches, no dimmers.
