Hi folks, looking for some advice:
This morning when the heating/hot water was scheduled to come on the RCD tripped. I traced the problem to the ring circuit, and then isolated various parts until I identified the fault in the central heating and hot water system - there is a fused switch to isolate it. It is a gravity fed system with cylinder, pump and 2 motorised valves in the airing cupboard, with a Glow-Worm Ultimate 60FF boiler.
I disconnected the thermostat, it still tripped. Then I disconnected the programmer from the wall plate, it still tripped. Likewise the CH and HW motorised valves. Eventually after disconnecting the live wire at the pump the RCD no longer tripped. The programmer was still disconnected at this point, but subsequently I can confirm that with everything else connected, connecting the pump is what causes it to trip. So, to me it looks like a faulty pump but before I call a plumber I just want to check it cannot be anything else - like leakage to earth from the flue fan which when combined with the pump is enough to trip the RCD? I don't know, I am really not an expert on this!
Secondly I am a little confused about why the pump would trip the RCD when the programmer is disconnected - is the live wire to the pump not a switched live from the boiler or programmer? Is it maybe the boiler still calling for pump (overrun?) even when the programmer is disconnected?
Thirdly what could actually cause the pump to fail like this? A blockage? The pump has been working fine, albeit the house is about 15 years old, and there is no evidence of water leakage around any of the components or electrics. Is it possible to isolate the pump and open it up to take a look or is this a really dumb idea for a DIYer?
Edited to add: job for plumber, or electrician?
