Hi everyone this is my first post here but I've lurked for a while and found some useful answers here in the past. I'm in the process of replacing the outside tap as the old one was wrecked by sub zero temp a few weeks ago. I bought a new tap and wall plate from screwfix (as there was also a leak from the original wall plate from the nut) I removed the old olive, fitted a new one, put the new elbow wall plate on however when I screw the tap on, the nozzle points skyward!!! I have tried starting it off at different angles but no matter what I do to tighten it so that it doesn't leak it ends up pointing upwards. I've used a good few wraps of ptfe tape. The pipe coming out of the wall bends 90 degrees upwards if that makes any difference. The leak at the nut holding the wall elbow joint onto the pipe is still there after the olive replacement despite the use of ptfe tape.
Any suggestions as to how to sort this would be much appreciated. I'll add a photo once I've charged my camera battery!
