N
Newboy
PTFE is designed to lubricate a screw fitting so you can get it tighter so it seals.
Rubbish!
On threaded joints the PTFE/Loctite55/hemp & compound form the seal - PTFE is used because is has a low friction
coefficient and will allow the fitting to slide over it without being pulled out of the thread.
Without a thread sealing substance the joint would leak.
