Second door bell connection
I've connected as instructed but still the original bell Chimes and not the new one.
Any advice appreciated.
I just pressed the button as normal only the original chime sounded. I have a volt meter I'll get it out tomorrow and give it another bash. I'll measure both voltages
your first bell is a ding dong and as said right at the start, your second bell would also need to be a ding dong to work properly, however as you are testing with a second chime the only way the second chime would work is if you press and hold IN the button.
Holding in the button, the first bell will ding and go silent, your second bell should start chime sequence, it may take a second or so to start.
When you release the button the first bell will then Dong and your second chime will stop.
With the button held in there should be about 10 volt AC at each end of the link cable
Thanks will try that tomorrow. So is the only way to get this second chime to work by holding in the door bell button?
Not in normal circumstances, but in your case it cant be used Without unnecessary work, It is not designed for what you want.
If your keeping the first ding dong bell then the only extension bell is a Ding Dong
Ok I'll try and borrow a ding dong bell next few days and try that. Hopefully like you say the transformer in my current one will work them both.
Here is a pic. It's the same reading on both chimes. When the button is pressed down, the reading drops to 0 and then back up to 15 when button is released.
I've bought a byron 765 from Argos attached is the instruction. How can I wire this one up? Given up on the other !
The and.
I've tried 0 and 3 initially so that activates the original ding and half dings the new one. This is without a button push. And the ding stays on the original and doesn't dong until it's disconnected.
Here's the original
So it's connected to the same terminals as the White wires are which are connected to the door bell button.
