Hi all,
I'm seeking for help with some multiple faults with my boiler and central heating.
I got a Baxi 2 Megaflo 28 Compact GA boiler and it suddenly stopped supplying hot water about two days ago (no big issues before except re-pressuring). I tried to reboot it however it lost power completely when I turned it off. The Honeywell central panel is functioning properly.
I called in a British Gas folk to assess the situation and he commented the following:
1. It may be the problem with PCB so it cannot be switched on
2. Our vertical flue has no support so need to get it done before any work
3. There is a minor leakage in the pipe beside water cylinder
The boiler is 4 years old and we moved in 4 months ago.
So my question is whether I should call original installer to see if they can get all fixed or I have to seek Baxi for the boiler and another plumber to deal with point 2&3.
The flue is quite firm and I wonder if there is an actual need for brackets, also will this be potential problem that my boiler is not working???
I've attached some pics here
Many thanks!!!
Many thanks!!!
