I have one of these cheap SDS drills:
http://www.screwfix.com/p/energer-enb465drh-4-8kg-sds-plus-rotary-hammer-drill-230-240v/63303
It's an Energer ENB465DRH 4.8kg SDS Plus Rotary Hammer Drill 230-240V
It has a clutch and seems relatively low RPM (850rpm no load, 40Nm max torque)
Can I use this to do a 100mm core in sandstone/brick, or should I just hire a diamond core drill for the day? By use this, I mean, without breaking my arm if it sticks? I've only got one hole to do.
If you think I can, what sort of drill bit would you advise I use?
Thanks!
Thanks!
