Nice cat.
What's your ceiling like? This sort of lighting will show every flaw in the plasterwork but having said that if the ceiling is ok it's a really good way to provide ambient lighting.
Seconded. You'll be surprised how much lighting from that angle can make it look like a moon-scape. Hold a lamp/torch up right next to the ceiling to see how it looks.
I have just reskimmed the walls and been through the whole ceiling myself with some easifill sorting out every tiny little blemish. I am now in the process of sanding it with 180 grit to smooth it down and get a really good finish. For the ceiling I am also planning on air spraying the paint to again minimise issues associated with getting the paint absolutely flat, so hopefully the ceiling will look really good.
That could be said about this forum too…………..there may be slight blemishes, but this does not detract from the look.
We only use the colour for the baby, the rest of the time it is warm white only. Having the option of controlling each wall is useful as you can turn just the back wall on when watching TV etc.personally I think it looks tacky - like an 80s disco, but fair play to you for doing what you set out to get.
You were warned it could be a problem, but assured us that your meticulous preparation would mean that it would not.Could have guessed that you would be the only person to have so much time available so as to pick up minor shadows and then go to the effort of pointing it out.
I think someone needs to be less touchy, and to not assume that other people in the world are as sad as them.I think someone needs to get a life and stop trying to get a rise out of people.
I would suggest that you look at what it actually means to "slate" someone in the sense that you used the term, but I fear that it would be a task outwith your ability.
Looking to do the same myself, new ceiling and walls so will have a new skim throughout , will be using the lightweight coving as it does not need fixing to the ceiling , easily holds against the wall only with adhesive.
