- Joined
- 8 Mar 2016
- Messages
- 8
- Reaction score
- 0
- Country
Good morning all, I am new here and need your help and advice. I am changing a fan in en-suite from a timer unit to a two speed inline non timer unit, I also have to connect through a new fused 3A switch unit. I have confirmed which cable does what but I have hit a snag as regards the switch live 2 core cable from the ceiling rose and the 3 core cable from the light switch.
The 2 core from ceiling rose consists of Live and the other core is being used as earth. The 3 core E N L is coming straight from the switch. I have established that the 3 core live isn't needed as the fan will run non stop. The unit being fitted has L N connections and doesn't need earth cable. Here come the questions:
a) do I isolate the 3 core cables (from switch) into a bloc and not use any of these cores at all?full disconnection would be better but want to keep cable in place in case I ever get another timer unit
b) untwist the earth core from 2 core cable (ceiling rose) and use as a neutral, therefore creating a L N connection for fan, if so, does it go in connection next to the second neutral cable already in the rose?
c)connect the Live and newly created Neutral into the fuse switch box?
d)connect L to fan unit and N to whichever speed connection I want to use in the unit?
Many thanks in advance
