I've got my IP44 fan to go in the hole in the wall. The wiring from the previous fan is ready to connect and............confusion.
The previous fan was a IP?? rated model with a timer built in. It had 3 core and earth cable feeding it via a triple (I think) pole isolating switch.
The new fan is an IP44 rated model without a timer. It appears from the instructions that this requires a different wiring configuration than a model with a timer.
The cable currently coming out of the wall at the "fan hole" comprises:-
An earth
A grey sleeved core with blue tape on it (assume N)
A brown sleeved core with no tape on it (assume permanent L)
A black sleeved core with brown tape on it (assume switched L)
This is switched by a triple (?) pole switch which sits outside the bathroom next to the light switch.
Examination of the wiring config in this large X-pole switch (the finger plate is nearly 2" wide!) shows 3-core and earth again with:-
These appear in the same locations on the "in" and "out" sides of the switch. Earth to switch back box.
Does this provide a reasonable picture of current wiring config?
The confusion is because:-
Wiring diagram in fan instructions only shows 2 wires going to the fan connection terminal - a live and neutral.
Vent Axia state that "the unit is double insulated (class II) and does not need an earth connection".
So which live do I connect to the fan? Black sleeve with brown tape or brown sleeve no tape? And what do I do with the earth where it comes out of the fan hole?
Hope this hasn't bored/confused anyone!!
![Laugh :LOL: :LOL:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
An earth
