Is my answer from Monday invisible?
It is a positive head pump. Such clearly states it needs 2m head.... Such, surprise surprise is where it starts to work when you lower the shower head.
Tell your installer to RTFM.![]()
Dan told you that on Monday
The head height is taken from the base of the cold water tank to the highest point, pipework in loft or the shower head.
If you haven't got a 2m head from these points there will not be enough flow through the pump to start it.
Why do installers not read instructions.
The problem is the distance from the cold water storage to the shower head. That's why the pump works when you lower the shower head to the floor.would say I have 75cm - 100cm from the pump pipework to the cold water tank. If it was moved to airing cupboard shelf there should be 2m, its just a shame there wasnt the room for it to go on airing cupboard floor
Pumps should not be fitted in lofts
I would only fit those pumps if the customer supplied them then when they leak it is not my problem.
I will only provide and fit S & T pumps link above
With the amount of problems you've had I would have thought you would want to get it right not penny pinch
