I'm posting this here as I feel it is more electrical related than plumbing.
I'm half way through my bathroom refurbish - and having spoken with a knowledgeable work colleague, I'm now in a quandary about my shower.
We bought the house about 6 years ago. The current shower was installed at the previous owners instruction - I don't know when.
The current shower is a "Scalemaster Softline SL80", which from their website (scalemaster.co.UK) appears to be 8.5kW.
I'm no expert, but looking at the current connected cable I would say it is 6mm².
Also, our fuse box has NO RCD's. The shower fuse is the one on the far left. I haven't pulled it yet so I don't know if it's rewirable or cartridge. I'm guessing it's 30Amp.
Now, here is the dilemma - the new bath is L shaped. To centralise the shower head will mean moving it across about 4 inches from its current location. Which will require moving the control unit and it's associated feeds.
If I'm going to have to move the pipe and cable slightly, then maybe I should consider a new shower at the same time (before I tile it all up).
My colleague has recommended I change to a power shower, and now I'm totally confused as to which way to turn...
So I'm left with 4 options.
#1 - just put the existing shower back, just moved over a few inches.
Not really happy with this due to the discovery on the electrics - pushing the wire and the fuse to the max with no RCD.
#2 - replacing with a lower rated shower, 7.5kW?
We have quite high water pressure and I'm worried 7.5kW won't be man enough.
#3 - get the wire replaced with 10mm².
Not really an option as we're getting into the "complete rewire" area, I don't have the money!
#4 - power shower. Replace the 6mm² with a 1.5mm²? 13Amp cable spurred off of an existing 13Amp circuit.
My colleague thinks this is OK to DIY, but I'm certain this requires part P (whereas simply replacing like for like does not).
If I go this route I WILL get an electrician in to be safe.
The problem with this (and at least I have access to the wall and the floor right now) is that I will need to cap the mains water feed and run new gravity feeds from the hot and cold supply.
So based on the above, what do you guys recommend?
