- Joined
- 27 Jan 2008
- Messages
- 27,419
- Reaction score
- 3,310
- Location
- Country
At random I selected an advert this one is for 5 LED MR16 lamps I have read and re-read the advert. No where does it state the voltage, never mind if AC or DC. It clearly does not have a multifaceted reflector yet calls than MR16 not MR16 compatible. It says the connection is GU5.3 I am sure it is actually G5.3.
OK question and answer does state it is 12 volt and can be fitted either way around. However that is some one trying to be helpful is may not be correct. At around 70 lumen per watt these are not very good on energy saving. However £19 for 5 is quite cheap.
Looking at a 180 lumen lamp which has all details the price is £9 each. It states 10 ~ 30 volt DC. Which would clearly need a new power supply. Lower output and twice the price and is down to 60 lumen per watt.
This Amazon advert does state 12VAC/DC it even gives the angle of beam. But the problem is it is really a suck it and see, no one seems to tell you the real spec on the lamp. Buying for Tesco or Asda is great, if it does not work you take it back. But selling a lamp without stating voltage does seem a bit off.
This one is 220 volt so it is not as if all G5.3 lamps are 12 volt. As to finding a lamp holder which is G5.3 and rated 220 volt well that is something else.
