We're currently in the process of planning a new kitchen. The existing electric oven is currently under a gas hob. We propose to disconnect the gas and install a induction hob and relocate the oven into a tall housing unit at right angles to it.
The existing arrangements are shown below.
The induction hob will be either a BOSCH PIE611B18E or NEFF T40B30X2, both of which I assume due to their rating would have to be hardwired into the existing cooker point (although I am not certain about the NEFF)?
The new oven will hopefully be a NEFF B44S42N3GB which is 13amp and looks like it can be fitted with a plug, so will be plugged into the socket next to the cooker point (Unless it would be easier/possible to hardwire both together into a dual connection point?).
We would like minimum disruption to existing electrical connections. But the main concern is that the the cable to the oven will be approximately 3-4m long (maximum 5m) to allow some slack for it's removal from the housing unit. We've tried to illustrate below how the cable will run. The 45A cooker switch for the oven & hob will remain within 2m of the single oven. But the actual cable length will extend this and we would like to know whether this would have a negative effect in any way?
