Good afternoon,
After several failed trips to the shed, I'm at a little loss to what I need.
I am trying to first fix a new bathroom and it involves a floor mounted tap for a freestanding bath.
I would like to use push fit under the floor (my apprenticeship was in electrics) and trust push fit over my go at compression fittings.
I also need some way of capping my flexi hoses so I can test the pipework.
Please attached image of supplied hose by manufacture, that screws into the bottom of the tap fitting.
It measures approx 14mm OD at the thread.
- I would like to replace this with a longer push fit flexi hose (but JG only do up to M12?)
- I would like some way of capping at the threaded end so I can test etc.
From this measurement is it likely that it's M14 and if so am I looking at wholesaler to get the bits I need?
Tap is from Victoria Plum (seems cheapish).
Many thanks!
Many thanks!
