Apologies - missed that.That's where I was going with this. I want the finished solution to be either accessible blanking plate or at least have a visual clue by way of a access door. the cables pop out of the wall to go to the CU at the moment and then chase down the corner to disappear into the (currently empty) electricity cabinet, so creating a safe zone/danger zone by using specifically a blanking plate(accessory, installation is not necessary.I assume I will have to leave some kind of removable cover on the surface, be that a door or a blanking plate, for maintenance
I thought you wanted to make it all invisible.I would love to bury the connections in the wall then plaster over the lot
You need to copy and paste the whole thing. The morons who wrote the software used by this site couldn't see anything wrong with it generating URLs which it then found unacceptable.I can't make the lollipop search link work
See http://www.diynot.com/diy/posts/3491458/
