Alarm Cable wiring on Upvc
11 Oct 2013
Yorkshire
Am fitting wired contacts/sensors to some upvc widows, but some of the wiring (6c) will have to run down some central pillars, so wondered how to keep the cable neat and straight ?
Could use superglue but know that will mess both the cable and frame if ever removed.
Wondered if it was generally practical to drill and thread the wire inside the the frame ?
thanks
If you can or worst case they do a single cable sticky back trunking , make sure you clean the frames before sticking it on .
Last time I looked at that trucking it was all the square type, but seems there is now a D shaped one in various sized, saw this micro one in BQ earlier and it looks very neat.
Also saw these pieces of U channel on ebay, a good idea to diy some, if I can find some 4/6mm plastic channel.
