I have attached a Pic. The ECV can remain in the original possition however the meter once the bathroom is made it will be in a "different" cupboard and i have been told it may need another ECV. As you see there is space enough, the plan is to move it under the RCD box. Since i have the choice of getting a smart meter for free this should make things easier. Does smart meters HAVE to be installed by SGN as well?
If you'd approached me as a customer North I would have no problem doing what you've asked after I'd explained some of what has been mentioned above, from what you've posted it seems a fairly straight forward job.
Smart metres? Don't get me started on them!! Suffice to say I will NEVER have one fitted in my house.
They'll more than likely put the metre in the same place, fitting a secondary ECV would be straight forward if needed.
