Bubbles under carpet
13 Sep 2015
Had my carpet fitted 2 weeks ago, the other day i noticed 2 pockets of air formed under the carpet which could be pushed down, like rippled almost.
They have now dissapeared, should i still get the carpet fitter to come out and restretch it or does this happen with new carpet?
How can i check if its tight enough before getting him out?
It may have relaxed down. If it is wool with a hessian back, you could sprinkle the bubbles with water and they will shrink down as they dry.
If there are actual ripples, try to push them to the edges of the room as you hoover, or it may need more stretching.
Its polypropelene with hessian back
'mmmm
you could try, but I don't think it will shrink. Polypropylene will withstand hot water.
'mmmm
Its gone now it just went away but its got me concerned the rest of the carpet isent tight??
If it was correctly stretched it should not form any ripples in the carpet, that is the whole point in stretching it in the first place. Poly may be a bit less forgiving compared to wool when stretched but not really an excuse.
It's possible the carpet may have been folded to get it into the room causing minor crease marks? If that's the case, sounds like they have eased out as they should do.
