I'm not entirely sure if this is the right section, but I'm looking to insulate my shed to store some tools in it. It's built using 44x44mm framing but most insulation seems to be 25 or 50mm. Will the 25mm work? Or will having a gap between it and the board I'll put over the top reduce or eliminate it's effect?
Or could I squeeze 50mm in there? Will it compress by 6mm? I'm only planning on using a cheap polystyrene board.
And, how would I insulate the roof and floor? Do I need to?
