upvc piping mods
25 Aug 2004
Cornwall
1 by mrcrow_uk, on Flickr
2 by mrcrow_uk, on Flickr
3 by mrcrow_uk, on Flickr
in my garage are two pipes for the laundry and are in grey upvc? plastic
i want to cut into and extend the cold so i can fit a garden tap at the front of the garage so i dont have to drag the hose round the front from the tap at the back outside of the property
this piping must be a bit old because i had my kitchen renewed and the "plastic" piping for that is white.
i would like to convert the 90* bend to an equal tee and so run the new piping about 2-3m and end in a standard garden tap to take my click on hose reel system near the up and over door end.
the cold tap for the washing machine seems to fit via an copper olive type compression fitting, and i have some spare compression bends i could use if possible
the two laundry pipes are from piping near the central heating boiler and have isolating valves fitted to them so i can shut down the cold to do this job.
cheers
geof
If your question is "can this be done" then the answer is 'yes'.
The plastic pipe is not old because it is grey, it is just a different brand/system!
Whether using compression or pushfit you will need to buy inserts for the pipe you have, to use at every connection - I.e you will need 3 inserts for a T and 2 for an elbow!
I would also lag the pipework where it is at risk of freezing and also a lever valve inside to shut off supply to the outside tap for the winter months and you will also need to put in a non-return valve in the pipework to the outside tap to comply with water regs.
thanks...i put a water tap in my old house and i will use the same one...it has a non return valve in it
glad you reminded me about that
what is that grey piping know as and can i use an olive to fit onto any brass compression fittings...which i have spare in my kit
cheers
geof
That doesn't comply with water regs. The double check valve is required to be internal
Jon
Hose Union Bib Tap with Double Check Valve 1/2" DZR to BS 1010 part 2
it will be this one from toolstation...is that ok?
cheers
geof
Jon
cheers
geof
No, you are required to have a double check valve inside the property to comply with water regs.
Jon
@mrcrow Find attached the water regs for an outside tap. Note that the Double check valve is required to be internal to be protected against freezing and that insulation is not classed as a protection against freezing only a delay against freezing. The check valve should be in a heated part of the property or provision made to ensure that freezing cannot occur.
Jon
Jon
that is pretty clear
the tap will be installed inside my garage...do you think it will be ok there in frost conditions?
i can put a frost cover on it...otherwise...where should i fit the required double check valve...the source of the cold supply is from the central heating boiler in the cupboard where its situated...and also used as a airing cupboard...there is an isolation valve there so i could cut into the pipe at that area and it would certainly not ever freeze
the rest of the pipework is all inside the garage which is attached to the house and fairly cool but has never shown signs of freezing
cheers
geof
Yes, copper olive preferably and also the correct insert for the pipe.
(y)
Looks like poly pipe or hep.
OP: does the plastic pipe have anything printed along it that would indicate the brand?
yes here we are...
P44 by mrcrow_uk, on Flickr
and thanks for your help
cheers
geof
Ok, polyplumb. So you need these...
https://www.google.co.uk/search?q=polyplumb+pipe+inserts&ie=UTF-8&oe=UTF-8&hl=en-gb&client=safari
(y)
yes here we are...
cheers
geof
ACE!!
very pragmatic
will now have a sort out of my spare compression fittings left over from past copper run jobs
i see fitting a T in place of a polyplumb 90* bend involves cutting back the piping which wont work as the existing pipework is pretty tight on that run...guess i will just cut in on the straight run a bit along..watching the K's...will need to get a pipe cutter...and fit a T and then use 2 90* to get the new run to the front of the garage and drop a leg to just above waist height to fit the wras valve...
well pleased with your help
cheers
geof
In practice Jon, I agree with your post above, but to be fair, the WRAS website states the following...
And while I agree with that sentiment we aren't talking about an existing installation. This is to be a new install to the front of the house.
Jon
