- Joined
- 25 May 2016
- Messages
- 4
- Reaction score
- 0
- Country
Having recently bought my first home, I've spent quite a bit of time browsing useful info on this forum - thanks for all the help so far!
The wiring in the (connected) garage is ancient and has been modified and bodged over many years to the point where it is quite simply, horrifying. It has a 1970 fuse box (5x fuses; 3x 5A and 2x 30A, the two-pin cartridge type with wire in the middle) that is grey and looks like it's been underwater for the last ten years. This is fed from the main house fuse box which is of similar vintage and doesn't appear to be on it's own fuse. The feed cable looks about 10mm2 at a glance. There is a strip light wired from one of the 5A fuses, and a radial circuit going to 3x 2-gang sockets with a mix of white and grey 2.5mm2 (red and black cores in both), and a 1-gang socket on the end. From the 1-gang socket (and this is the best bit), there is a flex cable running out of the back of the garage, through some hosepipe and in to the mostly-disintegrated shed up the garden.
I'd like to replace this lot with a modern consumer unit, wiring and new sockets/switches/light fittings. My plan is to get an IP65 consumer unit with 6A and 16A MCB's for lighting and a radial circuit respectively, run a light switch either end with it's own 4' strip light on 1.5mm2 T+E and four 2-gang sockets on a radial using 2.5mm2 T+E. I'd completely remove the hideous spur to the garden shed.
From the various reading I've done, I realise this is notifiable and would either have to be certificated by a qualified electrician or building control but I'd like to do the work myself to the correct standards.
Does what I've suggested sound reasonable? Can the cable be surface mounted in the garage or would it need to run through conduit? Do I need to consider anything else to make this compliant with the regulations?
Many thanks for any advice,
Mark.
Mark.
