Is that your actual deeds plan, or have you drawn in those red lines in that place to show the boundary as it is?
Just between 9 and 21, on the double lines, is a faint break in the lines - like a line has been erased. What's that?
It is difficult to scale from deed plans, as those lines could well scale to be 500mm wide which is more or less the disputed width of land.
The offset lines do seem random, so you can't seem to be able to measure of the main house garden boundary. But a logical assumption that all the plots would be the same width would be fair. So if that plot is wider, and yours narrower than all the others, then yes the boundary may have been built over.
