- Joined
- 11 Dec 2007
- Messages
- 425
- Reaction score
- 5
- Country
This is one to just satisfy my curiosity more than anything else.
At some point in the future i will be wanting a shed built from block. I was talking with someone & when i described the 4mtr-x-3mtr-x-2.4mtr(h) build i want they called it a garage. A garage in my eyes is a building you can stick your car in & since there's no access to the rear for a car then i call this a shed. But whatever, it's still a building of some description
The (4") blocks i know of are....
* 100mm solid block - "breeze blocks" which i see people building extensions out of. 7N typically although i've seen 10N.
* 100mm "lightweight" block - a little lighter than your standard 100mm dense block but not what i would consider 'light'. I think these are also 7N. You can probably get them in other ratings.
* 100mm "ultralight" block - the construction of these isn't as 'tight' if you will & they feel noticeably lighter than the above two. You may also have heard of them as 'klinker' or 'fibolite'.
* 100mm "paint grades" - a really tight fine construction which seem to take paint well. Like the first one i mentioned but tighter construction.
* 100mm 'thermalite' blocks - can cut them with a saw. The lightest of all of these. Durox, Celcon, Quinn Lite - all the same kind of thing. I think these are maybe used on internal walls?
I know you use the standard 100mm solid for things like extension builds but i'm more interested in why/where you would use the other ones i listed & specifically what you'd use if you was to build a shed/garage out of block.
Thanks.
Thanks.
