Hello!
I'm in the process of installing my bathroom and i'm wondering how is best to connect into the soil pipe. A tee pointing upwards will mean the flexi pan pipe i'm going to use likely would not have fall on it.
Is there a different type of tee piece i could buy that doesn't stick out so much, or other ideas on what i should do? could i just lay the tee piece flat if i can get a small flexi?
If i were to extend the tee so it was directly behind the toilet that would be better, but involved adding two more joints, one in the 110mm and another in the 55mm that joins it, i'm not sure where would be enough room on the 110mm to add another joint there.
Any suggestions on what is best to ?
thanks.
thanks.
