I would think it would be very unusual (if not unknown) for the Zs of a ring (pointless or not) to be higher than that of alternative radial arrangements, wouldn't it?All sockets on a pointless ring, despite the increased Zs ....
I understand, and largely agree with, the rest of what your wrote, but I think it incredibly unlikely that a ring would have a higher Zs (or VD) than radial(s) serving the same sockets. In fact, unless the routing of the ring cable was absolutely crazy, I doubt that it would be even possible!Probably, but you know what I meant.
I'm still confused. I still don't understand in what circumstances a ring serving a number of sockets could/would have a higher Zs than would radial(s) serving the same sockets. One would obviously usually expect the ring to have a considerably lower Zs.I should have said "despite the unnecessary increasing of Zs", although then you could have said it probably doesn't matter.![]()
Yes, that will often be true.I'm not saying that. I'm saying the oft quoted 'it's better if all sockets are on the ring' rather than have spurs is, in general, a waste of cable.
I'm still a bit lost. If your 'increase' is not relative to a radial, what does it relate to. A spur from a ring will (I think inevitably, but certainly usually) have a slightly higher Zs than would the same socket (or whatever) if it were part of the ring, wouldn't it?I, mistakenly from your point of view, said this would (unnecessarily) increase the Zs. I didn't say this would make it higher than a radial.
What do you mean by that? As often discussed, unless in reduced CSA cable, the concept of a 'spur' does not really exist in relation to a radial.The same would apply to a radial.
