I've had a new shed/garage built. New electrics were installed by an electrician, and were we all working ok. Perhaps now a mistake, i did not get the electrician do a first and second fix, I got them to do the job in one go, knowing that I would then install plasterboarded out one of the rooms. When plasterboarding out I detached from the wall the supply fuse box and slid plasterboard behind, but no wires were disconnected in doing this. However L1 & L2 as per the diagram weren't quite in the right place so I moved them. There was enough slack in L1 to move it, however I used a junction box and extra piece of wire to move the position of L2.
However now when I turn on the light circuit the RCD trips in both garage and main unit in the house. (after reading one other posts it mentioned that having RCD in series might not be normal???)
First of all I removed L2 from the circuit, then I removed S1 and L1 from the circuit, so that L1 is just acting as a junction box towards S2, and the circuit is still tripping. Luckily I can still access the wires by removing some of the exterior boarding, and have checked for damage to cables by screws, but can't find any. (can only visually see 80%) but all moving about ok.
Therefore i think I have removed as much as I can from the circuit in terms of changes made, but its still tripping. Have called electrician who installed it, but he's not available for 3 weeks. So posing here to see if there are any suggestions.
A few searches suggest a 'leak to earth' might be an issue, but I don't have any equipment that can test, unless any suggestions?
The picture of the light box is L1, and shows switched live cable disconnected, but L2 disconnected cable is out of shot.
Any suggestions of help greatly appreciated.
Thanks.
Thanks.
