I have a small 3 bed semi detached house with 7 radiators and HW cylinder. The boiler is a Potterton suprima 30 (non condensing) – It is a Y plan, microbore (10mm) unvented system - all fairly standard for 1999 I think. The system has been great and the boiler always fires however. 2 months ago the system became noisy (whooshing/gargling) so we drained it down cleaned with X400, flushed and refilled with X100. Everything was fine but before we did this we noticed scum/spores on the surface of the tank (I pumped this out and cleaned the tank to avoid introducing it to the system). After this process everything was fine until a couple of days ago. Now there is the same scum in the tank and the same noise. I literally run the HW for 10 minutes and have loads of air in the system. I bleed the pump and the coil and all quietens down. Before bed I turn the water off, bleed coil and pump. Next morning, I beld the pump and coil again and lots of air came out. Now 12 hours after bleeding and with the boiler being off, where on earth did this much air come from? I no the water will have contracted as it cools but surely water would have dropped from the FE tank to replace this?
My personal thoughts are organisms in system – try AF10 or blockage in the air separator. the latter seems unlikely as the system does drain and refill easily and if the air seperater was blocked, surely this would not be the case.
I am very confused as to how this large amount of air is entering the system in such a short time when the boiler is off. I have checked for leaks including under the floor – the manifolds and pipes all appear fine and none are magnetic (including the air separator).
I would really appreciate some advice as to what is causing this!!!
