I need to replace our 20+ year old Myson Orion 50B with something a little new more efficient.
I've been trawling through the forum and the web for current thoughts on what the best heat only boilers are at the moment and come up with about 8 different manufacturers, most I've heard of and a few new ones.
However our heating is slightly different to the norm so it might very well lend it's self to one or two models more than any others.
Basically we have a Kingspan Flowmax thermal store that the Myson currently heats.
Looking through the Kingspan info it recommends the following in regard to a suitable boiler:
Due to high operating temperature of thermal Storage Systems condensing boilers may not be cost effective - ?? What does this mean as I assume my only choice these days is a condensing boiler?
A boiler with a cast iron heat exchanger is far more tolerant of a system design when compared with one incorporating a "low water content" heat exchanger - again most are Aluminium aren't they?
When a boiler requires any form of pump overrun then the existing pump overrun device must be disconnected and our timed pump overrun device used in its place. The boiler pump overrun will be solely under the control of our timed pump overrun to ensure maximum efficiency. We don't have their overrun device so I guess it would be easier to get a new boiler that doesn't need pump overrun? If so then what's the best option?
The current out of our boiler is 15KW, was looking at 18KW boilers as we have added a radiator to the system since it was originally put in.
We have a 4 bed detached house with 12 rads. In terms of sizing kingspan state Calculate space heating as per BS5449 then add 3KW for hot water. The Flowmax and all pumps etc. was replaced by BG under their service care about 5/6 years ago so that side is much newer than the boiler.
Boiler makes I've looked at so far
Worcester Bosch - Greenstar 18si
Vailliant
Glow Worm as I read they don't need a pump overrun and are based on the Vailliants
Think I also read that Baxi boilers don't need the overrun either but not looked at them yet.
Then looked briefly at the following as they get good reviews on here
Veissmann
Intergas
Atag
So given the parameters of our current set up what should I be looking at? Once I have a few options then I'd like to see who the approved installers are close to me for each manufacturer.
Vailliant
Veissmann
Intergas
Atag
