- Joined
- 15 Nov 2005
- Messages
- 132
- Reaction score
- 1
- Country
Hi
I have a long rectangular room with 3 sides being external walls, the other being an internal one. It's a modern house so the internal wall is just a stud partition.
The room has 4 double sockets all on the same ring, and all mounted on the external walls.
I would like to add an additional double socket midway along the internal wall so I can hide power cables behind the TV unit which is in that location.
My plan was to take a spur from the nearest existing socket, and run the power cable horizontally to the new location. To do this will mean routing around the corner inside suitable trunking for regulatory compliance.
An easier option would be to run the cable down to the floor and in the small gap below the plasterboard, but I'm pretty sure that's not compliant with regulations.
I've struggled to find information about whether this approach will be compliant with regulations, or if I'd need to take the cable vertically up to the ceiling and then around the corner in the safe zone before dropping it back down to the new location.
Please advise about regulations, and also with any tips on how to run the cable and what trunking to use.
