WPD fit Proteus DP Isolators too. The ones with the stupid 3mm Allen key terminals. Why 3mm? Snappy snap snap.Eon obviously appreciate quality…… NOT
DS
Bet they're a boat-load cheaper than Wylex
DS
You've not had to deal with npower too much, thenEon obviously appreciate quality…… NOT
DS
………….. but if the TP board has a 63 amp and the CU a 50 (electric shower - and the max I'm ever likely to need), then won't the CU go first and leave the TP alone?If there are 2 MCBs (one in the 3 phase board and one in the smaller CU for the individual circuit), when a fault occurs it's anyone's guess as to which one will disconnect. Perhaps it will be the one in the CU so only a single circuit is disconnected. Or the main one in which case the entire CU has been disconnected because of a single fault.
Ah ha!! Mechanical. Nearer my skillset. Might I suggest trying a backup of an old fashioned, imperial 1/8" allen key.Awful those Proteus hex terminals, the last ones I had to fit were in a load of 100a blocks (which I later took out and replaced) the 3mm hex ranged from 3mm to about 3.4mm so an allen key only fit some of the screws, the larger holes it just spun round! I had to bash in a torx screwdriver to get them to turn. The heads were all wonky and misshapen, total rubbish.
If you shop around well enough, you can pick up schnieder RCBOs for MUCH less than the list price.
eBay is great, if you're careful. Only go for new ones, ………………...
Make sure if you go that route to only buy the new style (with the curved white is test button around the toggle) or the old style (with a grey test button under the toggle) it'll look proper gash if you mix the two
Go with the newer ones. I'm not 100% sure the older multi9 breakers and RCBOs properly fit the new acti9 boards.
Have not tried old Rcbos in the new Acti 9 boards.
Due to the fact, the old style are obsolete, we do have problems fitting the new rcbo,s in the older boards, mainly they dont seem to clip in right, though occasionally do fit.
physically the fitting looks identical, so it seems odd, we recently reused the mcbs in a damaged board and the old style mcbs fitted the new board fine, the issue seems only with the rcbos.
So yes I would agree that its possible you could have rcbo problems
As per others id get the latest cream colour ones so all looks neat
Also , im not sure you intended to, that them ones in the pic fit Easi 9 boards and only fit the Acti 9 boards
For a moderate overload it would.. but if the TP board has a 63 amp and the CU a 50 (electric shower - and the max I'm ever likely to need), then won't the CU go first and leave the TP alone?
Ta, flameport, I understand that, now.For a moderate overload it would.
For a short circuit where 100s or 1000s of amps will flow, both devices will disconnect in approximately the same time (a tiny fraction of a second), so there is no way to know which will disconnect first.
