Don't forget this weekend, put the clocks back and start boiling the sprouts for christmas Day!
Fine, thanks. Good to see you, too, and I trust all is well with you.Blimey, some old names here. Hi John, TTC and SS. Hope you are all well?
He fairly recently 'resigned' because of what he regarded as an irreconcilable difference with admin/mods over a matter of principle (he is a very 'principled' man). Ironically, given the countless occasions on which he probably would have been thrown out of many/most forums (but wasn't thrown out from here), it does actually seem that he was essentially 'in the right' as regards the issue which resulted in his withdrawal.Whats happened to sheddy?
I must say that rather surprises me. Perhaps the cutout fuse, as well as the cutout itself, was 'elderly', and had somehow become a bit 'trigger happy'?It turned out that they had 2 electric ovens and hob on the go, as well as a TV, most of the lights, a tumble dryer, and someone was using an electric shower. As a result the fuse in the elderly cutout, (60A I seem to remember) had failed.
Hi SS. Hope you are all well?
Nothing likes Christmas. Something horrible always happens at Christmas.must have been like it for yonks but gave up the ghost when the turkey went in
Yes, I did two or three years ago (and, I think, reported it here), and it wasn't appreciably lower than normal - if I recall correctly, not under 240V (my normal is 240-245V).Perhaps because everyone is cooking the voltage goes way down. Anyone measured it?
Yes, that's also my understanding, as far as the generation is concerned. However, reduced voltage as experienced by consumers due to high demand is likely to be primarily due to VD in the transformed LV feed to their premises (and some VD in the HV supply network), even if the voltage generated and supplied to to the network is little reduced.I thought it was the mostly frequency that dropped when too many people were cooking, not as much the voltage? But there's some rule that you are due a certain number if cycles over a day so they have to catch up later.
