- Joined
- 15 Nov 2005
- Messages
- 132
- Reaction score
- 1
- Country
Further to this post: http://www.diynot.com/diy/threads/adding-a-plug-socket-round-a-corner.467371/
I still intend to DIY extend the ring circuit and add 2 double sockets side by side behind my TV. My plan is to run the cable horizontally from an existing socket. The length is about 50cm from the existing socket to the corner of the room (external wall), then 250cm from the corner to the new socket position (internal stud wall). The house is <5 years old and has RCD protection on the consumer unit. I expect both walls will have Celotex type insulation behind the plasterboard so I am prepared to remove an entire channel of plasterboard and Celotex, and remove notches in the studs to pass the cable through. As such, the cable will be just behind the plasterboard. I believe this is OK with RCD protection and observation of the safe zones, but I may add conduit if advice here is to do so.
I believe I'll be using Twin and Earth cable.
What I need to do next is work out the correct diameter of cable. For that length of run, that fixing technique and the environment that the cable will be in. And also, for the use of 2 double sockets (possibly with a 4 gang extension lead) running an LCD TV, PS4, Wireless Router, Soundbar, Humax Freeview box.
I'm not sure of the power consumption of all that, but a similar TV seems to be about 85W so must be no more than 1kW total. One website calculator suggested that 1mm sq cable would be sufficient, but I wanted to get more informed advice before continuing.
