This is such an issue, I use a combined helmet and visor......maybe not as much protection but at least you can see when the angle grinder digs into a knuckle
John
You can also rub undiluted shampoo on the surface with your fingers, and polish it off with a soft cloth. Both the goggles and the cloth must be perfectly clean, or you will put a pattern of tiny scratches on the surface. Wash them in clean water with a tiny bit of WUL, never try to clean lenses dry. Builders dust is very abrasive.
If your face is hot and sweaty, wash or wipe it dry first.
I've gone for stanley wraparound safety specs but I've found stuff (bits rather than dust) can still get past them into my eye so I may go for some goggles and dig out the Sea Drops from my scuba gear. Sea Gold is meant to be pretty good (works for multiple dives).
