Hi
A friend has an issue with her downstairs rads not reaching full temp, so after some basic diagnosis (bleeding rads, refilling system) I found that by unscrewing the knurled ring on the TRVs and removing the top part that the rads became fully hot. This was rather a surprise to me as I thought that the most anticlockwise position (or specifically the 'V' marking on the Caleffi TRVs) was fully open. I've swapped several around and they all exhibit the same behaviour. As I unscrew the knurled ring I can hear the water flow entering the rad, even when the TRV is on max. The valve pins all seem to move freely. I checked the Caleffi site but their support docs page is 'Not Found'
Are TRV thermostats interchangeable i.e. can I just swap the top part for another make?
Is this normal? If so then do I need to increase the flow/pressure of the system somehow?
