What am I doing wrong?
30 Jul 2013
London
Hello
I am constantly finding myself having to replace this white wire in my ceiling lamps. I replace it, it works for few weeks then stops. When examining the wire it seems burnt down from the heat, I replace it and again it repeats itself.
Any idea what am I doing wrong? Perhaps I need to buy better quality ones? Any suggestions?
For the MR16 range of lamps there are many versions, some need cooling air at back of lamp, and the lamps again you have dichroic which is a special reflective surface designed to let heat pass and only reflect light, with the GU10/GZ10 base the dichroic can only be fitted in the GZ10 so no mistake can be made, but with the G5.3 base both lamps fit into the same base, the latter is often 12 volt.
So could be wrong type of lamp holder, wrong type of lamp, or simply a lamp which is too big.
DH may well be right. If it is a fire-rated type fitting, it could be that you are supposed to use aluminium-backed lamps, not dichroics.
There should be a label on the inside where the lamp sits to state this if it is the case.
What does that red label say?
This burnout is common with the 12V MR16s, but it usually takes a few years to occur, not repeat within a few weeks (in my experience). Just to clarify, is it burning out at the lamp end or at the terminal end? If the lamp end that's normal, though, as I say, not that often. Check you're not using 50W lamps with fittings intended for max 35W (though there shouldn't be significant heat difference) and there's no obstruction over the top of the fiting to stop the heat dissipation. If the burning is at the terminal end, that suggests the terminal screws aren't being tightened enough. Best bet for a long-term solution is stop trying to fix this problem and replace with LED lamps or fittings.
Thanks for all the valuable advises.
Here's what the sticker says, so perhaps I should be using specific wire or lamp?
That's not relevant.
If the room above is also your property, fire rated fittings may not even be necessary nor required.
It's odd that you didn't post a picture of the burnt part.
Presumably you must be replacing the lamp holder as well?
Thanks.
The floor above also belongs to me yes.
When I say 'burnt' I mean this white wire connected to the lamp holder exposed and looks like the plastic cover of its wire turned black which to me indicates high heat and burning.
I don't replace the lamp holder when it happens only the wire however given that it sporadically happens with different lamps something tells me I'm either using the wrong wires or the wrong lamp...?
As Securespark has indicated, those fire-rated fittings probably require 'heat forward' lamps, which would explain the lampholders burning out so quick.
Don't hear about fire-rated spots these last few years, since the advent of LED spots...
Fire rated not required, then.
Yes. No doubt.
I was assuming (and I think others too) that they were GU fittings (or similar) which only come with wires fitted.
Are they R80s (or similar) with an SES lamp holder?
Is the lamp holder making a poor contact with the wires or the lamp, thus creating excess heat?
I too had assumed they were GU lamp holders, doesn't look big enough to be an R80.
I'm curious, if they are GU, how the OP is replacing the cable but not the lamp holder. This fact, or the lamp holder may be the issue.
Also, the top of that can looks mint, no signs of overheating or even age discolouration, so I'm going for a high resistance joint somewhere causing the heat over the wrong lamps.
