- Joined
- 6 Jan 2017
- Messages
- 14
- Reaction score
- 0
- Country
Sorry about the confusion as well - I did mean the main socket in the wall.
And would that be some sort of design fault in the lamp?havent read all the replies and cant see a picture so lots off assumptions here
i personally would swap the bulbs over and if it blows again suspect there a greater buildup off heat or less dragging the heat away
just a thought![]()
Might try a LED type and see, thanksI quessed you use a halogen style lamp, it is not unheard of for temperature to affect bulbs when switched on, could the tall lamp be in a colder part of the room.
If you dont have a Dimmer on the light, have you considered Led lamps, some retro ones look no different from the old Tungsten lamp and will proberly last at least 2 years
Tom
I would have thought not realy practical for a plug in lampIf you really love your light as is, i.e. you like many other people prefer halogen bulbs rather than LED or energy saving lights, there are ways you you could avoid d giving them a thermal shock, ( if one was able to observe the filament during switch on, it can really jolt violently, so to prolong the life of your bulbs is to use a dimmer that ramps up starting to full power, or you can try a manual dimmer switch that may help but you need one that switches off by turning fully anticlockwise and clicks off, not the push button ones, and each time you need to switch on you click on and turn clockwise to full power.
Quite so, particularly when one does not really have to expend any effort at all (not to mention considerably reduced running costs and longer life {even with dimming}) to change to non-filament lamps!True, it is not readily achievable unless you go out of your way to build or supply a dedicated dimmable power source, ....
Tried them in what?So unbeknown to me my wife grabbed a bulb from the cupboard (she said 60W and I suspect they were filament) and it went immediately, as did the next one she tried.
Halogen bulbs are (a type of) filament bulb.You seem to be suggesting it is some kind of thermal shock and that both filament and halogen bulbs are susceptible whereas LED is not? Is that right?
