Indeed, but as you've said, even that does not usually constitute 'energy wastage' during the Winter.The majority of hot water heat loss is through the pipes, which is why they should all be insulated. They rarely are.
It would be, but I said "usually" and the usual situation in a usual house does not involve insulation between floors, so a substantial proportion of heat lost from pipes provides useful heating (in Winter).Is warming the air in a floor/ceiling void which is thermally insulated from the rooms above/below not wasteful?
And lets not forget the standing losses of a combi. Unless put in "be as annoying as possible" eco mode, these things fire up from time to time to keep the (DHW) heat exchanger hot.Hot water cylinder heat losses are typically between 1 and 2 kWh per day for a modern insulated cylinder.
Some of the newest types can be less than 1 kWh. Older ones will be more, but unless it's an ancient totally uninsulated copper thing, the losses and the cost per year are usually insignificant.
Specified losses also assume it will be hot for the entire 24 hour period, and that the loss to the air is wasted - in reality the cylinder may not be heated all the time and in the winter any losses will contribute to the heating of the building.
Generally not - at least not to a significant degree.Is warming the air in a floor/ceiling void which is thermally insulated from the rooms above/below not wasteful?
Whilst that's true, it's really only related to the length (and insulation) of the pipe runs, not the difference between stored and 'instantly-heated' hot water ....It does constitute water wastage though, as there's no way of reheating the water in the pipes. But that's another topic!
I think that's pretty standard in hotels etc., and I presume it must be very wasteful of energy (at least, in Summer).Actually, in some stored water installations, there is a return fitted so that water can be circulated to ensure that hot taps are "instantly" hot. Various ways of controlling it, and in commercial installations (eg hotels) there are valves designed specifically for the end of line to control the flow.
Wasteful? It may waste a little energy (although in commercial installs, pipe lagging is far superior to domestic), but due to the lengths of pipe runs, the water saving is huge.I think that's pretty standard in hotels etc., and I presume it must be very wasteful of energy (at least, in Summer).
It's certainly not a new idea. In my present house, I inherited what appeared to be a largely Victorian plumbing system. Water heating was by a solid fuel boiler. When the boiler was running, there was a constant flow (by convection) of hot water through loops of (mainly ~2" iron) pipework - not just to ensure 'instant hot water' at more distant taps but the 'loops' also zig-zagged through a couple of 'walk-in' airing cupboards to keep them constantly heated.
True. If one's only concerns were financial, one would obviously have to do the sums, since water is probably fairly cheap in comparison with energy.Wasteful? It may waste a little energy (although in commercial installs, pipe lagging is far superior to domestic), but due to the lengths of pipe runs, the water saving is huge.
I think someone has already done the maths, as for the last good few years, washing machines have not had a hot feed for this very reason.True. If one's only concerns were financial, one would obviously have to do the sums, since water is probably fairly cheap in comparison with energy.
