Socket Spacer Plates
4 Sep 2014
Manchester
Hello,
Silly question I'm sure but I wanted to check before purchase.
Can I use any double socket spacer plate with any other double socket?
I am thinking of getting these from Screwfix:
http://www.screwfix.com/p/schneider-electric-lisse-2-gang-spacer-white/2105j?_requestid=410488
Which are for these:
https://www.electricalcounter.co.uk...t/1999781414?gclid=CLK81OzCxNECFcMp0wodhEkOoA
The reason is that some of the sockets just don't have the space for them to run flush with the wall so some will have spacers.
I would just like to confirm as I can collect them tomorrow and get them put in if they will be OK.
James
Well, the screw holes will be in the same place but they may not be exactly the same size or corner shape as your sockets.
is the problem, that the metal backboxes in the wall are too shallow? Or there is too much cable to squash it flat behind the faceplate?
Post some photos please. Sockets vary in bulk.
The problem is that the back boxes are too shallow. The cables are also the wrong colour for what they do but that's another job for another day.
I have attached a picture of the socket below.
FFS THOSE CABLES ARE WIRED INTO THE WRONG TERMINALS!!
turn off the power and do not use the sockets until this is corrected.
Yes that's correct they are indeed and I am in the process of doing this currently I just need advice on the spacer so I can fit the socket.
That socket does not fit because it's a horrid flat fronted type and requires a box which is 10mm deeper.
Any standard socket will fit there without a spacer.
You can't as the product is out of stock and not available to order either.
As for the wiring - how could anyone get it that wrong when the terminals are colour coded.
Was the old socket connected like that
I cant believe that it would have been
As for spacers, they will look rubbish, flat plate sockets are designed to be, well err flat.
Most spacers are likely to be smaller than the plate anyway.
Can you not just get fancy normal sockets and forget about spacers
Is that not his new socket, I read it that he just copied the OLD socket.
That old socket being connected same but the colours not being L N E as they should be, which seems hard to believe
EDIT
The sockets you have linked too state they fit a 25mm box which you have, so why do you want spacers
the old socket (if "old") would not have had two earth terminals. The terminals might have been arranged differently.
Ok to clarify a few things...
The old socket was connected as shown in the picture. I did check the labels on the terminals to confirm and made sure they went to the correct terminals. I checked after connection and the socket tester says it's cabled correctly. I still think it's wrong and I am going to test the cables when I get my multimeter from the garage.
I appreciate what your saying about the flat plate but it doesn't go all the way in hence the need for a spacer.
James
