Hi all,
moved into house 6 months ago and central heating system is old and i know boiler needs replacing (Boiler is a Baxi WM51/3RS) but it's working for now and i will do so when i get cash (aiming for next 12/18 months) i "believe" it's a gravity fed Y Plan 2 Valve system? not really sure. have hot water tank in airing cupboard and cold tank in loft.
i've replaced the programmer and thermostat to give us more control and to lower bills a little in the short term.
Original was:
Switchmaster400 Programmer
British Gas RS2 Thermostat
i've replaced it with a tado smart thermostat + extension kit and it's working how it use to as the switchmaster400 could only have "heating+ water" or "water only" there was no heating only switch.
To be able to control them independently i believe additional wiring needs to be done? just not sure what
the tado is capable of independent control and i believe i can even wire in my hot tank thermostat to get current temp? (not really bother if can't just want independent control atleast)
any help would be much appreciated!!!!
Current wiring had CH ON & HW ON + N L + Earth nothing else. attached pics of setup + wiring.
wiring in terminal block casing
x1 white cable, top left on pic goes to red cased pump/valve, which i believes the central heating valve?
x2 grey cables, top right on pic comes out of floor from boiler
x1 black cable, bottom left on pic goes to black/dark blue cased valve which is connected to hot water tank (believe this is hot water valve?)
x1 white cable bottom right comes from the hot water tank thermostat (switchmaster)
Original was:
