Dimmer switch for dimable LED BC bulb
A 250w dimmer might not work as the wattage for that bulb is only 12w. Dimmers usually require a minimum load in order to work as intended, so its advisable to get a dimmer specifically for LED/low wattage. Unless you happen to have a lot of bulbs in a single chandelier.
Do you know what dimmer you have? or are you looking to get one?
looking to buy. can't see a low wattage option on toolstation. so probably need to go screwfix. it seems most have 60w min.
