How do you know this without taking the case off, ?
Well, if I close the two thermostat wires, that's electrically identical to putting a bridge on the pins they're connected to in the boiler?
It's not the same as the boiler generates its own 24v for these terminals.I could put a bridge across, but it'd be the same as when I shorted them at the thermostat.
Link Live to the 240V RT connector (with the power off of course) then check briefly that the boiler will fire.
If that works ok you just need to remove the link and take a single wire from Heating ON to the RT connector to get the thermostat working.
electronics, I'd work around the latter, having school qualifications and a degree in that.
On the plus side you've saved all that money on having the Hive fitted by a so called professional
I still don't understand why Bg engineers have been running round installing these for 99 / 149 yet folk are still paying more money to blow stuff up themselves.
