I'm going to be running new network cabling through our house and I'm planing to do it using flexible conduit so I can easily change the cables in 10 years or more time if needed without having to pull up carpet and take plasterboard off.
However I'm not sure of the best way to get the cables from A to B and what joists to drill through. Ideally I want to use 32mm flexible conduit for each acces point upstairs which all leads back to a patch panel under the stairs. This however means I will have to drill 5 x 34-36mm holes next to each other through one or more joists to get to under the stairs. With building regulations stating that the minimum distance between holes should be 3 times the diameter (centre to centre) that means that the total distance taken up by conduit on one joist would be about 47cm.
Is there an easier way I can get the conduits to my patch panel? Judging by the research I've done I'm guessing not many houses in the UK use conduit to future proof cabling as I can't find many examples of it.
