i'm not sure where to place this one.
Which way should the wheel turn in a Klargester BioDisc?
My electrician changed the motor 6 months ago.
I've just had a belt. snap, which I put down to a full tank.
As you do when you have it open, I was watching the wheels move and it has 2 little cups on the side , which I guess are for introducing air into the mix. My disc turns so that the bottom of the cup hits the water first and the air escapes at the surface as the cup submerges. I would of thought that if the cup goes in open side first the air is trapped and gets released at the bottom of the mix as the cup starts on its way back up.
Is it possible my wheel is turning the wrong way? If so how do I reverse it??
Cheers,
Jez.
Cheers,
Jez.
