Your posh oak floorboards- spiked on top of the original boards were they? Get your yellow pages out, get ringing round for a part p electrician to do you an EICR and price for sorting your meter cupboard out. And take it from there.....
You might consider immediately replacing the fuses in the two boxes on the left with lower-value ones, if they are 30A.
Yep, that's what the Henley blocks, 25mm tails and DNO to isolate the power while electrician does the job would do. Up to you whether you replaced those 2 boxes at the same time but it would be an ideal opportunity, especially if they're doing all the power, to tidy the job up- an RCD in line wouldn't hurt eitherJust before I go to sleep.. would it not be far easier to replace that cable with bigger cable instead? It's only a short tail.. ?
Yep, that's what the Henley blocks, 25mm tails and DNO to isolate the power while electrician does the job would do. Up to you whether you replaced those 2 boxes at the same time but it would be an ideal opportunity, especially if they're doing all the power, to tidy the job up- an RCD in line wouldn't hurt either![]()
Simply not being earthed would not result in that sort of tingling, unless you're greatly exagerating with the telephone comparison.
That needs to be investigated.
Read up on "mainteance free junction boxes".
Do you have RCD protection in the consumer unit?
No qualified electrician would dare own one of those things...About that "tingle"... Well, I can give you something to compare it to now.
Whilst I agree that they are of very limited usefulness (and potentially dangerous if used for the wrong purpose) I'm not sure that a survey of the toolboxes of 'qualified electricians' would necessarily confirm what you have suggestedNo qualified electrician would dare own one of those things...
I certainly have some - but I'm not a 'qualified electrician', so that doesn't really count!Dare to admit to owning one?! ( there are 3 or 4 here, but not in my van)
Please do yourself a favour and throw your neon screwdriver away, or stop using it as an indication of voltage. They are spectacularly unreliable and must never be trusted as proof that a circuit has been isolated. If you're going to do any more of this sort of thing, a cheap multimeter from anywhere will come in very handy (eg for working out which core in a cable is the one you want) as well as being a more reliable indicator of voltage
Other than what?I find the other type ....
Indeed, as I've just written, they do have their uses, but only in the hands of people who know and understand what they are doing, and what are the limitations of the devices.... useful for quick identification of, for example, a switched or permanent line and other things like that.
